[GRASS5] v.in.ascii / v.out.ascii : attributes are not transferred
Stefan.Neumann at agrar.uni-giessen.de Stefan.Neumann at agrar.uni-giessen.de
Thu Oct 19 12:03:44 EDT 2000
Hi Grass,
with
v.out.ascii input=<vectorfile> output=<outputfile>
I can export a vector file. I have tested this feature and I noticed some points which seem peculiar to me.
This command creates .../dig_ascii/<outputfile>  with the vectors and ../dig_att/<outputfile> with attribute-information. According to "Grass 5.0 Programmer's Manual" (Okt 5. 2000) I expected it to also create ../dig_cats/<outputfile>. This is missing, even thought there are attributes attached to the <vectorfile>.
Then I immediately imported the <outputfile> again with
v.in.ascii input=<outputfile> output=<someothervectorfile>
I expected that <someothervectorfile> has the same attributes as <vectorfile>, but it had no attributes at all. Apparently v.in.ascii did not import the attributes stored in .../dig_att/<outputfile>. Is this correct ??
Also I compared the format of .../dig_att/<outputfile> with the specification on page 45 of the Manual. It does not exactly match, the columns are different.
Please let me know if I made an error or if the modules mentioned above are not working correctly.
TIA, Stefan
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20001019/51427b4d/attachment.html
