[GRASS5] attribute lines
David D Gray ddgray at armadce.demon.co.uk
Wed Oct 18 10:18:31 EDT 2000
Hi all,
Is there a definitive spec for the formatting of a line in a dig_att
database file? There are several options in src/include/dig_att.h. You
could use that to format the lines with write_att() but that truncates
the decimal digits to 2, which is not satisfactory in many instances.
Also it does not produce lines the same length as those created by some
other modules.
David
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
