[GRASS5] Re: GRASS: Old code in openvect.c
Markus Neteler neteler at geog.uni-hannover.de
Wed Oct 18 05:46:17 EDT 2000
On Wed, Oct 18, 2000 at 09:44:02AM +0700, Justin Hickey wrote:
> Hi David
> David D Gray wrote:
> > I don't have any plans to keep this.  I recently suggested that the
> > backward compatibility stuff be deprecated. I think that is the best
> > option, rather than just removing the old stuff straight away as these
> > routines are apparently needed to open old maps (I used grep to track
> > back through the call sequence). Maybe we can rip out the old rubbish
> > in one go during the 5.1 devel sequence.  So I would leave it for now
> > (maybe put a marker string in to remind us that it is to be removed -
> > eg /* ***DEPRECATED*** */ ). But if it is really inconvenient I'm sure
> > no-one would miss it, but if you still have doubts, you could perhaps
> > ask on the mailing list. No-one objected to my proposal to deprecate
> > however.
> It's not inconvenient, I just like to clean things up when I see
> something like this. Keeping it is fine with me and I'll put in the
> marker string you suggested.
> Markus, should we start marking files like this with the (/*
> ***DEPRECATED*** */) marker David suggested?
Yes, please go ahead. When building the new 5.1devel, we can take out this
stuff.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
