[GRASS5] small fixes
Markus Neteler neteler at geog.uni-hannover.de
Wed Oct 18 05:14:12 EDT 2000
On Tue, Oct 17, 2000 at 08:28:10PM +0200, Andreas Lange wrote:
> Hi,
> i checked in small fixes to src/libes/geom and src/raster/r.combine.
> Please tell me if you have problems recompiling.
> Could someone do some tests on the modules using the geom library
> (s.geom, v.geom)?
Thanks for fixing, Andreas.
Please note: s.geom is not yet updated to GRASS 5 API. So it
does not work at all.
Markus
PS: If bugs are missing in BUGS, please modify the file directly.
    If bugs are already fixed, remove them from BUGS. Thanks!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
