[GRASS5] WWW and Grass.
roberto micarelli mi.ro at iol.it
Fri Oct 13 17:51:40 EDT 2000
Federico Ponchio wrote:
> Hello,
>         im working to a www interface for grass.
> It should allow to easily build up and customize a web page which allow
> exploration of maps.
> It is possible to "bind" several maps in a theme, specifing grafical
> attributes for single objects (colors, labels, masks fonts), range of
> visibility, and many other things.
> Moreover It is possible to link attributes to values in a database ie: i
> can choose colors of inhabitated zones using the "population" field from
> a table. (actually im supporting postgres and informix).
> If you wanna see the result of a working demo try this link (works only
> with a recent netscape at the moment) and it is under heavy development.
> Im sorry it is in italian... but think its so easy to understand it does
> not matter.
> www.ambientepi.arti.beniculturali.it:2020/pisa/pisa.html
> I plan to make public a decently finished version quite soon, im only
> waiting for the entity "regione Toscana" to pay me for the work.
> I feel the need of some feedback, advices, critics, whatever, so
> if you are interested i can give out details of my work.
> There are many questions i would like an answer, expecially if you think
> that this piece of code can become a part of Grass.
> Thank you for your patience.
>                                 Federico
Per me non e' un problema che sia in Italiano :)
Ho visto il tuo sito, sinceri complimenti. E' molto interessante.
Mi presento.
Sono Roberto e scrivo da Roma. Sto lavorando per il GRASS allo sviluppo di
un network-analyser che si integrera' alla parte vettoriale digs, principalmente
concepito per il calcolo del costo dei percorsi.
In realta' ho un'idea piu' ampia di cui il net-analyser e' solo una
componente...
Lavoro in un'azienda allo sviluppo di un system-manager ma di notte
programmo per il mio sistema. Tutti i miei sforzi per trovare persone
all'altezza e disposte a lavorare alla progettazione della mia idea sono
sinora stati vani.
Anch'io sto integrando dei sample cartografici di navigazione in
Postgres.
Prima di vedere il tuo sito ero molto orientato all'utilizzo di
Map Server, ora non sono piu' cosi' sicuro. Map Server nella prossima
versione supportera' l'interfaccia ad OGR, e quindi OGDI. Una mia idea
sarebbe quindi un driver OGDI/PostgreSQL per integrare il mio lavoro
ad altri GIS. E poi chissa'... magari un wrapper CORBA per ulteriori
integrazioni.
Ma non e' tutto.
Ho scelto la strada piu' difficile dei sistemi free-source non per
convenienza ma per.passione e per un certo credo metodologico
Se ti interessa parlarne scrivimi.
Credo che il tuo lavoro verra' favorevolmente accolto nel gruppo GRASS.
Distinti saluti e complimenti ancora.
Roberto Micarelli.
P.S.: Mi sono concesso di darti del tu pur non conoscendoti, ma spero
non ci siano problemi.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
