[GRASS5] CVS - grass compilation on linux and IRIX
Markus Neteler
neteler at geog.uni-hannover.de
Fri Oct 13 04:18:12 EDT 2000
On Thu, Oct 12, 2000 at 06:47:01PM +0200, Andreas Lange wrote:
> Hi 2 all,
> on linux my last compile did'nt work because of the mentioned problems
> with $(BIN)/grass5. I hope that a new CVS update solves this. Please
Hi Andreas,
now the $(BIN)/grass5 is back o.k.
> On Irix i can now compile, the culprit was IMHO that the SGI make was in
> my path before the GNU make, so that it didn't work as expected.
> But the tiff/png and tcl/tk libraries are not found by configure. So a
> whole bunch of modules is not build. I'll send the error.log another
> time.
Please tell me the paths of your local installation. I will add it
to configure (I expect it is somewhat non-standard on SGI).
> One suggestion: could someone modify the make targets in a way that
> makes it possible to delete all object files and libraries and re-run
> configure without deleting the binary installation? Or what is the name
> of this target?
Justin... ?
Regards
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
