[GRASS5] Re: [GRASS-COMMIT-CVS] CVS update: grass/src/general/init
Justin Hickey
jhickey at hpcc.nectec.or.th
Fri Oct 13 02:54:29 EDT 2000
Hello Huidae
> Date: Thursday October 12, 2000 @ 12:41
> Author: cho
> Update of /grassrepository/grass/src/general/init
> In directory intevation.de:/tmp/cvs-serv11603
> Modified Files:
> Gmakefile init.head
> Log Message:
> patch for non-interactive startup
> affected env variables:
> GISDBASE
> LOCATION_NAME
> MAPSET
> LOCATION
> basically grass5 takes it's argument which is LOCATION.
> 1. without any env variable
> grass5 - interactive startup
> grass5 interactive startup
> grass5 GISDBASE/LOCATION_NAME/MAPSET non-interactive startup
> 2. with GISDBASE env variable
> grass5 LOCATION_NAME/MAPSET non-interactive startup
> override GISDBASE like this:
> 3. with GISDBASE and LOCATION_NAME env variables
> grass5 MAPSET non-interactive startup
> override GISDBASE and LOCATION_NAME like this:
> 4. with GISDBASE, LOCATION_NAME and MAPSET env variables
> grass5 non-interactive startup
> override GISDBASE, LOCATION_NAME and MAPSET like this:
> 5. with LOCATION env variable: override GISDBASE, LOCATION_NAME,
> MAPSET vars
May I make a suggestion? Perhaps "grass5" should be used for interactive
startup for all cases. That way, the behaviour is consistant for all
users when they start grass with "grass5". Then "grass5 -" could be used
for non-interactive where appropriate. Basically, you would switch
"grass5" and "grass5 -" in your 5 cases above.
By the way, could you please post proposals for new features to the
developers list before you commit them to the CVS tree? This not only
gives the other developers a chance to comment on your new feature, but
can save you time as well - like yesterday when you found out your new
feature was duplication.
Just some suggestions.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
