[GRASS5] Re: CVS update: grass/src/general/init
Markus Neteler neteler at geog.uni-hannover.de
Thu Oct 12 04:44:50 EDT 2000
On Thu, Oct 12, 2000 at 12:05:51PM +0700, Justin Hickey wrote:
> Hello Huidae
> grass at intevation.de wrote:
> > Date:   Wednesday October 11, 2000 @ 16:20
> > Author: cho
> > Update of /grassrepository/grass/src/general/init
> > In directory intevation.de:/tmp/cvs-serv8316
> > Modified Files:
> >         Gmakefile
> > Log Message:
> > create $(BIN)/grass5 shell first then
> > if $(UNIX_BIN)/grass5 exists and writeable copy $(BIN)/grass5 to
> > $(UNIX_BIN)/grass5.
> > This process is useful for non-root GRASS install.  Only $(BIN) is
> > required to be writeable.
> This change has caused a crash on my system. Here is the error message
> that was reported.
> GISGEN: src/general/init - Thu Oct 12 11:50:49 TST 2000
> /usr1/grass/grass64/grass/src/general/init
>   mkdir OBJ.mips-sgi-irix6.5
>   make -f OBJ.mips-sgi-irix6.5/make.rules
> /usr1/grass/grass64/grass/bin/grass5 not found
> *** Error code 1 (bu21)
> GISGEN failure at STEP: src/general/init
> Please check your changes. This module compiled fine for me before. I'm
> not sure what the problem is but my definitions of BIN and UNIX_BIN are
> as follows (if this helps)
> BIN = /usr1/grass/grass64/grass/bin
> UNIX_BIN = /usr1/grass/grass64/grass/bin
> As you can see they are the same.
Hi Huidae, hi Justin,
just to report: now it compiles o.k. (thanks to your new patch).
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
