[GRASS5] How to code NULL in sites lists?
Eric G . Miller
egm2 at jps.net
Wed Oct 11 11:31:11 EDT 2000
On Wed, Oct 11, 2000 at 04:18:55PM +0100, Markus Neteler wrote:
> Hi all,
> I just don't know how to code NULL in a sites list with
> floating point data...
> Example:
> 3570018.250000|5766419.000000|-35|%0.86
> 3570018.250000|5766419.000000|-45|%1.04
> 3570018.250000|5766419.000000|-110|%*
> ^^ this shall be no data.
> Is that correct?
Yes, but how will code check for any NULL attribute? I don't think the
current library functions will allow NULLs for any attribute. It's
probably a good idea to allow, but library functions will have to be
modified (not to mention modules). Can we rely on using NAN to indicate
a NULL value for a double and a zero-length string for NULL string
attributes? I know there are problems using NAN on older systems.
Still, I think we should allow it, since it's completely logical that a
site may not have a value for a particular attribute while others do.
If the library functions are modified, I don't think we need to
introduce yet another special character into the site_list file format.
Simply having the metacharacter followed by a space should be enough to
flag a NULL attribute. The library functions need to be taught that
this is okay.
3567.1234|1234.567|#1 % %234.45 @"my label" @"alt name"
12345.009|1254.234|#2 %23.54 %22.123 @"the label" @
/bin/sh ~/.signature:
Command not found
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
