[GRASS5] grass-sites
Helena Mitasova - staff helena at gis.uiuc.edu
Wed Oct 11 10:00:50 EDT 2000
I very much agree with Andreas - please keep the ascii site format
in GRASS. We had an extensive discussion about exactly the same
issue - whether to keep ascii sites or get rid of it and keep
site data within vector format. The overall conclusion of that
discussion was to keep the ascii sites because of the same
reasons as Andreas cites here. Darrel extended the format,
but, unfortunatelly, the GRASS was shut down at CERL before we
were able to finish the work on the new sites format - so that's
why there are still things that do not work properly, it is similar
as with the floating point (although that seems to be in a pretty
good shape now), nviz and all the volume modules.
Helena
>I don't think that the sites format should go completely, because it
>makes small, timesaving hacks possible and is very intuitive. For many
>types of data (samples in ecology etc.) a simple point format is
>sufficient and convinient (IMHO). Topologically the point format would
>belong to vectors, but i think that many functions in GRASS are only
>available with the sites modules, so that it would be a lot of work to
>reimplement those with vector modules. I don't want to miss the sites
>files in GRASS.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
