[GRASS5] Re: next_step
Markus Neteler
neteler at geog.uni-hannover.de
Wed Oct 11 06:38:27 EDT 2000
On Wed, Oct 11, 2000 at 04:42:20PM +0700, Justin Hickey wrote:
> Hi Markus
> I just had a thought that we don't need the src/CMD/next_step/ directory
> anymore. The grass make process continues if any errors are encountered
> so it will always go through all modules. Thus the purpose of the
> next_step directory (allowing compilation to continue where an error
> occured) is now redundant. What do you think?
Hi Justin,
the *only* use is, when you interrupt the compilation process
and restart it again. But nowadays machines are quite fast, the
process could even be started from scratch and the compiler would
run through all stuff again (partly without compiling).
I agree to remove it. It is even a good idea to start the
"make install" always from beginning as new users don't know
that they have to delete the src/CMD/next_step/* file if they
want to recompile the entire thing.
Developers, any objections here?
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
