[GRASS5] compiling problems on IRIX
Andreas Lange
Andreas.Lange at Rhein-Main.de
Tue Oct 10 15:58:46 EDT 2000
i tried to compile the current CVS tree on IRIX 6.5 with the GNU c
compiler on sunday.
I had no luck because autoconf finds all libraries in /usr/lib and
/usr/freeware/lib, but with the -n32 switch all binaries are build in
n32 format, which has its libraries in /usr/lib32 and
/usr/freeware/lib32. This affects mainly all modules that use ncurses,
so that no usable installation is compiled.
I am not familiar with autoconf so that i had no luck to make changes
myself. What is the relation between the header files in
src/CMD/head/os-specific and autoconf?
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
