[GRASS5] Re: [GRASS-COMMIT-CVS] CVS update: configure
Markus Neteler
neteler at geog.uni-hannover.de
Tue Oct 10 09:57:34 EDT 2000
Hi all,
On Tue, Oct 10, 2000 at 12:17:19PM +0200, grass at intevation.de wrote:
> Date: Tuesday October 10, 2000 @ 10:17
> Author: cho
> Update of /grassrepository/grass
> In directory intevation.de:/tmp/cvs-serv2707
> Modified Files:
> configure
> Log Message:
> modified to find libpq-fe.h automatically without --with-postgresql option.
> If not found, postgresql support doesn't set.
> You can also use --without-postgresql/--with-postgresql option.
Due to this update we are able to modify the "NVIZ" configure
again. I propose that
- the local configure of NVIZ will be kept like this, but
- the Gmakefile will be generated automatically with sensivity to
PostgreSQL support
Results:
- the user can easily override the standard settings by running the
local configure
- a standard Gmakefile will be generated based on variables tested
by global configure
- if the minimum requirements are not fulfilled, the Gmakefile should
not be generated.
I feel this is subject to change in 5.1devel later. But we should have
a rather stable version for the forthcoming 5.0stable.
What do you think?
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
