[GRASS5] Even More on Projections
Andreas Lange
Andreas.Lange at Rhein-Main.de
Fri Oct 6 14:32:01 EDT 2000
Hi Frank, hi Grassprogrammers,
Frank Warmerdam wrote:
> Andreas,
> It hasn't been my experience that G_get_projinfo() returns defaults if
> PROJ_INFO is missing. Are you sure that it does? I had proposed changing
> G_get_projinfo() to generate defaults from the proj/zone settig in the
> WIND file if there was no PROJ_INFO file, but I didn't get any feedback
> (positive or negative) on this suggestion.
you are of cause right here. It was just wishful thinking on my side.
The call to G_get_projinfo() echoes that the file PROJ_INFO was not
found. But contrary the call to G_get_ellipsoid_parameters gives default
values (and the new functions for the datum support too).
G_database_projection_name() gets a name for the projection even if the
PROJ_INFO file is missing (from the WIND/DEFAULT_WIND file?).
I think that this all needs some work to be consistent. This should be
discussed again when grass 5.0 is released.
> As part of r.in.gdal I have implemented a projection comparison function
> (though it isn't really complete) which currently just lives in with r.in.gdal,
> but if folks think it is worthwhile, I would be happy to move it into libgis.a.
> static int
> G_compare_projections( struct Key_Value *proj_info1,
> struct Key_Value *proj_units1,
> struct Key_Value *proj_info2,
> struct Key_Value *proj_units2 )
> It returns TRUE if they appear to be the same, otherwise FALSE.
Yes, i would vote for including in the gis library.
I think that we should discuss how we can manage projection and datum
conversion in one step (different from my approach with the coordinate
conversion library), so that the {v|s|r}.proj commands can use a single
function call for conversion (with proj4).
But all this requires some user input if datum conversion is really
needed.
Thanks for your patience,
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
