[GRASS5] Is $(MATHLIB) now always required for linking to libgis ?
Eric G . Miller
egm2 at jps.net
Fri Oct 6 00:25:45 EDT 2000
Just added the little G_readsites_xyz() function. When I rebuilt my
test program against the new library, the linking failed with an undefined
reference to 'log' at line 629 in put_row.c. This was contrary to
compiling the same function less than a week ago. Adding $(MATHLIB), of
course, made this problem go away. Wondering if this is desirable
behavior, and will it possibily break a lot of programs than don't have
$(MATHLIB) specified in their Gmakefile's?
/bin/sh ~/.signature:
Command not found
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
