[GRASS5] Proposal to deprecate
Bernhard Reiter
bernhard at intevation.de
Thu Oct 5 05:26:08 EDT 2000
It is always good to keep compatibility.
But is can be done by a seperate conversion script.
We only need to provide one conversion path for each data file version,
so no need to make a real intelligent conversion file suite.
Bernhard
On Tue, Oct 03, 2000 at 07:13:06PM +0000, David D Gray wrote:
> Bernhard Reiter wrote:
> > is it possible to maintain a conversion programm/script of some sort,
> > which can only upgrade v3 format files to v5?
> It would be v3 <-> v6
> The problem is that the design of the version portability code makes it
> difficult to maintain portability across more than two versions
> simultaneously.
On Wed, Oct 04, 2000 at 08:55:33AM +0100, Markus Neteler wrote:
> On Tue, Oct 03, 2000 at 05:40:09PM +0200, Bernhard Reiter wrote:
> *if required*, such a converter should be sufficient. I am working
> with GRASS for many years now and never had any dataset in dig3
> format. Maybe we can ask the <grasslist at baylor.edu> if anyone is
> still interested in dig3, but I think (hope) that it is history.
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20001005/d5a640a5/attachment.bin
