[GRASS5] bugs-rst-rflow
Mike Thomas mthomas at gil.com.au
Fri Sep 29 18:37:37 EDT 2000
> David (r.flow question) the -M flag has never been tested
> so there indeed may be a bug - are you getting that even if
> you run it with a small file? The problem may be also with the
> segment library which is used e.g. in r.watershed for large
> data sets. Is the -M option really needed? Is the aspect(dir) that
> you are using derived from your DEM (fill) or is it different?
> please answer directly to helena at gis.uiuc.edu
Please CC the results of this discussion (or even the discussion) as I'm
also interested.
Cheers
Mike Thomas.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
