[GRASS5] PERL guru wanted for g.html2man
Markus Neteler
neteler at geog.uni-hannover.de
Wed Sep 27 12:23:49 EDT 2000
Hi again,
it is planned to generate all man/ and cat/ pages from
HTML (html/html/) and to remove the man+cat section from
CVS. There is a script "g.html2man" slightly doing this
job. But the quality is still poor as it does not
detect <p> (but <P>) and other tags. The script is
here:
src/scripts/contrib/g.html2man/g.html2man
written in PERL. Frank Warmerdam and me would be glad
if a PERL wizard could look at it and correct such bugs
(and probably implement missing standard tags).
Or: If you know a better script, we can even replace the
existing.
This should be an issue for GRASS 5 stable as it prevents
us from extra conversion work (to generate the MAN files).
Thanks for listening
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
