[GRASS5] Ideas
Justin Hickey jhickey at hpcc.nectec.or.th
Mon Sep 25 02:14:17 EDT 2000
Hi Tim
Tim Cera wrote:
> 1) Separation of the code from the interface.
I have already started taking steps to do this. But my proposal will
allow any interface to be used, including HTML. Basically when a grass
program needs to print or input data, it does so through a generic
function call. That function call checks which interface is being used
and then calls the appropriate function in the interface code. If you
want a specific interface, you only need to code the interface
functions. You would not have to touch any Grass core functions.
I am only doing a small part of this. As you say, it will take a lot of
work to do all of grass. But at least I will provide a model that others
can follow.
> 4) All monitors should be stopped automatically if you quit GRASS, or
> at least ask if you want to stop all monitors.
This already exists in tcltkgrass under the quit menu item.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
