[GRASS5] readsites() TODO list...
Eric G . Miller
egm2 at jps.net
Thu Sep 21 21:27:58 EDT 2000
On Thu, Sep 21, 2000 at 10:07:56AM -0500, Bill Brown - staff wrote:
[snip]
> I think your G_readxyzsites would be quite useful. I'd still like to
> see "cat" added as an attribute, though. G_writexyzsites might be good
> too. I think these would be more useful to the programmer because it
> hides all the messy Site structure stuff. For G_writexyzsites, if "cat"
> is selected, you could default to writing a double cat or add another
> RASTER_MAP_TYPE parameter which would be ignored if string or floating
> point attribute are chosen.
I see no problem adding support for the cat value. I could add the
RASTER_MAP_TYPE thingy too. I must say, I'm a little confused by the
use of floating point cat values. I always thought of a 'cat' as a
category which implies an integral value (even if it represents a range
of floats). I don't understand how a floating point cat makes sense for
a site file either. But, this is probably another matter...
> >int type, /* 0 = Z-dim, 1 = double, 2 = string */
> >--- This is the attribute type. By "Z-dim", I mean any of the n-dims
> >--- in the Site file spec. Double, is double attribute, string is
> >--- string attribute. Yes, an enum or #define's are in order.
> Z-dim is still confusing to me. Maybe I'm just being dense. So is
> Z-dim 1 the same as easting and Z-dim 2 the same as northing? If so,
> let's just call it "dim" - if not, "n-dim" might be better. When I
Okay, to my mind, every dimension after the easting and northing is a
z-dim up to the cat or label or ... I don't think well in more than 3d!
Call it a limit of perceptual reality. Anyway, I can call it just 'dim'
or 'ndim' to be consistent with the Site struct. To me, a 'dim' could
be in any spatial direction, but since the easting and northing are
already accounted for ... you're left with the z-axis (discounting time,
and other n-dimensional geometries). I don't see using those 'dims' for
anything other than the Z-axis -- there are double attributes already to
represent other things not defining the geometry.
[snip]
> >Anyway, shall I look at writing a generalized G_readsites() (and maybe
> >G_writesites() ?) using the standard Site struct? I'm ambivalent.
> Me too. I'd consider these "convenience" functions.
Well, we'll let that rest for awhile. I was going to look at some
parsing problems with s.in.ascii anyway. I may not have time to do
anything for a week or so, going out of town...
/bin/sh ~/.signature:
Command not found
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
