[GRASS5] Wish: wildcards in command line
Bernhard Reiter bernhard at intevation.de
Thu Sep 21 13:32:30 EDT 2000
On Thu, Sep 21, 2000 at 06:28:45PM +0100, Markus Neteler wrote:
> a "problem" I regularly face (and my students...) is that you
> can't use wildcards in GRASS/cmd line.
> Suppose you want to patch 20 adjacent images or DEMs, you
> have to specify all the names on command line. It would
> be great to have:
> r.patch in="dem*" out=mybigdem
> Or:
> g.remove rast="*"
> I am dreaming of such a feature since years... :-)
> Do you consider this is feasible (Obviously the parser would
> need to be modified).
Hmm I do not think it is a good idea to add this capabiltiy to
each grass command. Actually, this only works with unix commands,
because they already can accept mutliple arguments (like rm).
A start would be to add wildcards to g.list and maybe a flag
to produce a comma seperated list.
r=`g.list -l type=r dem*`
echo $r
dem1 dem2 dem3
r.patch in=$r out=mybigdem
In the case of r.patch and g.remove, we could add the functions,
reading the files from a file, making it even simpler.
g.list type=r dem* | r.patch inlist=- out=mybigdem
This would be unix tradition.
I would be interested to know how many commands actually do
need more than one or two map parameters from the same type.
	Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project				            (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000921/3f1e2c8a/attachment.bin
