[GRASS5] Reading Projections
Bill Brown - staff brown at gis.uiuc.edu
Thu Sep 21 11:27:54 EDT 2000
>The G_get_cellhd() function allows me to get the projection number, and zone, but
>doesn't appear to have support for additional parameters of complex projections
>(like Transverse Mercator's central meridian for instance).  The
>G_get_projinfo() call (used by r.proj) appears to get a full set of parameters,
>but does so by reading the locations PROJ_INFO and PROJ_UNITS files.  It seems
>to me that the location's default projection might be different than the
>projection of a particular raster in that location ... is that right?
No, each GRASS location is by definition all one projection.  If you have data
in a different projection, you have to create another location and import it
using r.proj or v.proj.
- Bill
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
