[GRASS5] readsites() TODO list...
    David D Gray
    ddgray at armadce.demon.co.uk
    Wed Sep 20 12:04:03 EDT 2000
Hi Eric
I started work on upgrading the routines in s.surf.krig to Sites5 (and
other GRASS5 features). In fact I've completed this part to an initial
draft, though I have had thoughts about a generalised routine for
reading sites (I wasn't awre of readsites() ):
"Eric G . Miller" wrote:
> A week or so ago, I looked at the TODO list and thought I'd look into
> this readsite() library function.  I arrived at the conclusion that the
> call would have to be different to support reading z-dim, double-att, or
> strtod(string-att), for generating an *xyz struct.  Anyway, I already
> did one iteration that added support for the z-dim, but I wanted to put
> up this call interface for comments.  We could make it a readsites2()
> and retain the other interface for awhile.  I don't know how many
> modules actually use readsites() at the moment.  Anyway, please let me
> know if the behaviors described here look awful (I'm still new to coding
> for GRASS).
> /* readsites: Reads a sites file converting to a site struct of xyz values.
>  * The Z value can come from one of the z-dimensions, a double attribute,
>  * or a string attribute converted to a double with strtod().
>  * If 'num' is less than one, attempt to read entire site file, otherwise
>  * read 'num' records.  The number of records read is returned.  If an
>  * error occurs, a negative value is returned.  The caller can decide to
>  * abort or retry.  Error values are:
>  *      Couldn't allocate memory                                -1
>  *      Attribute 'type' not found                              -2
>  *      Attribute 'index' out of range                          -3
>  *      Format error in file (includes conversion error)        -4
>  *      Something else (probably never happen)                  -5
> typedef struct _site {
>         double x, y, z;
> } site;
Could we not just use the struct Site, it has all these fields and more
info? Arrays would not get over large because as I read your code, it is
intended to make multiple calls anyway.
> int readsites(
>         FILE * fdsite,  /* The FILE stream to the sites file */
>         int    num,     /* Number of records to read */
Perhaps this could be for maximum number of records per call. Extraneous
conditions or EOF might interrupt the read sequence.
>         int    type,    /* Attribute type: 0 = Z-dim, 1 = double, 2 = string */
>         int    index,   /* The field index (1 based) for the attribute */
>         int  * done,    /* No more records in file? 0 = false, 1 = true */
Perhaps this would be returned in the status value. EOF is 1 normally I
think but here it would have to be a negative value.
>         site **xyz      /* The site array, caller must free between calls */
This might be best as a static field with file scope, ie. struct Site
**sites. This would allow the value to be preserved between calls. It's
more convenient than a passed parameter, but also it makes restarting a
read sequence from a previous position easier - I'm thinking ahead here
- functions like readsites_continue() could be added later. Some static
control parameters would also have to be stored, to keep track of the
stream.
David
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
