[GRASS5] CRAY T3E compile errors
Markus Neteler neteler at geog.uni-hannover.de
Wed Sep 20 08:57:15 EDT 2000
On Wed, Sep 20, 2000 at 03:56:57PM +0700, Justin Hickey wrote:
> Hi Markus
> Markus Neteler wrote:
> > /home/t3e/fsn/nhdc/nhdcmark/grass5/src/libes/digitizer
> > sh-48 /home/t3e/fsn/nhdc/nhdcmark/grass5bin/gmake5[7]:
> > OBJ.alpha-cray-unicosmk2.0.4.X/make.rules: file already exists.
> >   make -f OBJ.alpha-cray-unicosmk2.0.4.X/make.rules
> > cmd-2415 make: line '158': 'syntax error'. Stop.
> > Make: "/home/t3e/fsn/nhdc/nhdcmark/grass5bin/gmake5 digitizer": Error
> > code 1
> > -> I can't see any problems in libes/digitizer/OBJ*/make.rules
> >    But somehow it is different to other make.rules files?!
> I came across this type of error before in the old grass code (that is,
> I haven't seen it recently). The line at the stated line number for me
> was something like
> $(LIB): # in case LIB changes.
> I'm not sure, but this sounds like the LIB target contained something
> like -lm which is an invalid target. Check to see if the line mentioned
> is something like this, then check the definition for the target to make
> sure it only contains proper values (if it is a LIB target it should
> only have -L values).
The affecting line is 158:
cat make.rules:
   153  OBJ = \
   154          $(OBJARCH)/graph_input.o
   155
   156  all: $(DIGITLIB)
   157
   158  $(DIGITLIB): $(OBJ)
   159          $(AR)
   160
   161  #$(LIBDIR)/linkm.h: linkm.h
   162  #       rm -f $@
   163  #       cp $? $@
   164  #       chmod +r $@
   165
   166  $(OBJ): #linkm.h
I can't see an problem... Strange.
> > /home/t3e/fsn/nhdc/nhdcmark/grass5/src/libes/gis
> >         cc -g   -I/home/t3e/fsn/nhdc/nhdcmark/grass5/src/include  -c
> > fork.c
> > -o OBJ.alpha-cray-unicosmk2.0.4.X/fork.o
> > CC-140 cc: ERROR File = fork.c, Line = 32
> >   Too many arguments in function call.
> >         setpgrp (0, getpid());
> > 1 error detected in the compilation of "fork.c".
> > Make: "cc -g   -I/home/t3e/fsn/nhdc/nhdcmark/grass5/src/include  -c fork.c
> > -o OBJ.alpha-cray-unicosmk2.0.4.X/fork.o": Error code 1
> > cmd-2436 make: Stop.
> > Make: "/home/t3e/fsn/nhdc/nhdcmark/grass5bin/gmake5 gis": Error code 1
> > -> mhhh, no idea here
> As you can see from you man page listing in your reply to Bernhard, the
> setpgrp() function on the cray does not take any arguments. You could
> use #ifdef's as you suggested but it would be much better to have this
> determined by configure. Unfortunately, I have no idea how to do that.
Good luck for me: I have detected the problem. I fork.c there is
already an #ifdef statement. Reason fro my problem was that the
ksh on CRAY was in a "noclobber" mode. By setting
set +C
By that I got rid of strange write errors while running "configure"
(affecting src/includes/config.h). Now, after re-running configure,
the SETPGRP_VOID  was set properly.
.. src/libes/gis compiles now.
> > /home/t3e/fsn/nhdc/nhdcmark/grass5/src/libes/proj
> >         rm -f OBJ.alpha-cray-unicosmk2.0.4.X/bch2bps.o
> >         cc -g  -I. -I/home/t3e/fsn/nhdc/nhdcmark/grass5/src/include  -c
> > bch2bps.c
> > CC-167 cc: ERROR File = bch2bps.c, Line = 141
> >   Argument of type "UV **" is incompatible with parameter of type "void **".
> >         freev2(d, nu);
> > 1 error detected in the compilation of "bch2bps.c".
> > Make: "cc -g  -I. -I/home/t3e/fsn/nhdc/nhdcmark/grass5/src/include  -c
> > bch2bps.c": Error code 1
> > Make: "/home/t3e/fsn/nhdc/nhdcmark/grass5bin/gmake5 proj": Error code 1
> Here, d has probably been defiined as type UV ** in bch2bps.c and as you
Yes, that's right.
> saw, the first argument to freev2 is a void **. Therefore, d needs to be
> cast to a void ** as follows:
> freev2((void **) d, nu);
> Unfortunately, this could be dangerous since the structure of UV
> (whatever it happens to be) is unknown to the freev2 function. This may
> not be a problem but should at least be considered.
Probably I should put the cast into an #ifdef depending on config.h?
But: what variable I would have to check from config.h? Sorry, here
I am very unexperienced.
> > /home/t3e/fsn/nhdc/nhdcmark/grass5/src/libes/segment
> >         rm -f OBJ.alpha-cray-unicosmk2.0.4.X/address.o
> > address.c
> > CC-20 cc: ERROR File =
> > /home/t3e/fsn/nhdc/nhdcmark/grass5/src/include/segment.h,
> >  Line = 39
> >   The identifier "off_t" is undefined.
> > -> probably a problem with includes/config.h ?
> I think you're right here, which means another visit to configure.
Also fixed by above set +C setting and re-"configure".
Here a new error occured:
CC-852 cc: ERROR File = get_row.c, Line = 29
  The expression must be a pointer to a complete object type.
        buf += size;
1 error detected in the compilation of "get_row.c".
-> I am hesitating to change anything "intuitively"...
   Recommendations?
> > /home/t3e/fsn/nhdc/nhdcmark/grass5/src/libes/vect32/georef
> >         rm -f OBJ.alpha-cray-unicosmk2.0.4.X/curses.o
> >         cc -g   -I../digitizers -I../libes
> > -I/home/t3e/fsn/nhdc/nhdcmark/grass5/src/include  -c curses.c
> > CC-147 cc: ERROR File = georef.h, Line = 27
> >   Declaration is incompatible with "int suspend(int, int)" (declared at line
> > 359
> >           of "/usr/include/unistd.h").
> >   int suspend(void);
> > 1 error detected in the compilation of "curses.c".
> > Make: "cc -g   -I../digitizers -I../libes
> > -I/home/t3e/fsn/nhdc/nhdcmark/grass5/src/include  -c curses.c": Error code 1
> > Make: "/home/t3e/fsn/nhdc/nhdcmark/grass5bin/gmake5 georef": Error code 1
> This is again similar to the setpgrp error and should be dealt with in
> configure.
Or probably an #ifdef environment, too? I try to search for another
suspend() call...
Thanks so far
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
