[GRASS5] updated config.guess, config.sub
Markus Neteler
neteler at geog.uni-hannover.de
Tue Sep 19 10:07:39 EDT 2000
Hi all,
currently I try to compile GRASS on a CRAY T3E.
Due to problems with host detection I have updated the
config.guess and config.sub to latest version. On my
linux box it results in a slightly modified $(ARCH) name
OBJ.i586-linux-elf -> OBJ.i586-pc-linux-gnu
As much more host systems are supported, I feel this update
makes sense.
Probably you will either remove the "old" OBJ* directories
or rename them by a find/mv command.
Kind regards
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
