[GRASS5] Re: New d.rast.pg problem
Anantha Prasad/NE/USDAFS aprasad at fs.fed.us
Fri Sep 15 11:46:36 EDT 2000
Hi: I think I found out the problem with the r.mapcalc - I think it is a
bug in r.mapcalc.
Here is my report.
 r.mapcalc does not like it if the cellvalues are very high for eg.,
initially I put the col=fips
which ranges from 1001 to 55141 - it core dumped ... I guess the limit in
r.mapcalc is 32xxx which is a "huge" limitation. So, I changed to col=ppt
which ranges from 413 to 1853 ...and  had no problems with r.mapcalc.
I hope this limitation is removed in the grass5 official release.
GRASS 5.0beta8 > d.rast.pg key=FIPS tab=curr_pred col=ppt lab=avgt in=fips
out=navgt
GRASS 5.0beta8 > r.mapcalc avgtf=@navgt
EXECUTING avgtnf = ...  100%
CREATING SUPPORT FILES FOR avgtnf
range: 1.9600000381 22.3400001526
Again, I'd like to thank you Alex for your support - that  really enhances
the wonderful database functionality you have introduced to Grass. I hope
to be able to contribute my model-chooser with Tcl/Tk - R-statistical and
Grass GIS software to the public in the near future....in the meanwhile, I
hope I can continue to seek your support.
Best regards,
Prasad
Mr. Anantha Prasad, Ecologist/GIS Specialist
USDA Forest Service, 359 Main Rd.
Delaware OHIO 43015    USA
Ph: 740-368-0103  Email: aprasad at fs.fed.us
Web: http://www.fs.fed.us/ne/delaware/index.html
Don't Miss Climate Change Tree Atlas at:
http://www.fs.fed.us/ne/delaware/atlas/index.html
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
