[GRASS5] Thought on my CVS problem
Bernhard Reiter
bernhard at intevation.de
Fri Sep 15 04:01:47 EDT 2000
On Wed, Sep 13, 2000 at 03:25:09PM +0700, Justin Hickey wrote:
> Bernhard Reiter wrote:
> > On Wed, Sep 13, 2000 at 02:50:28PM +0700, Justin Hickey wrote:
> > > But these files are platform dependent (especially the autoconf files).
> > configure should not be platform dependent.
> > Most free software packages coming with a ready to run configure
> > and lex and yacc output files.
> > So you can compile without proper automake/autoconf installed.
> > But you need this as a developer if you want to create configure.
> OK, but the main reason I said they were platform dependent was due to
> the amount of differences between the CVS files and those generated on
> my machine. See for example, the src/raster/r.weight/inter/gis_pars.c
> file. Click the following link and choose Diff to previous 1.2 from
> version 1.3
> http://freegis.org/cgi-bin/viewcvs.cgi/grass/src/raster/r.weight/inter/gis_pars.c
> As you can see, the files are completely different and I don't know if
> the compiling one on a different platform will cause problems or not.
> What do you think?
You were probably using completly different versions of yacc oder bison.
I see no reason why a good bison output should not be platform
dependent. If it is, then we cannot bring the preconstructed files
with the standard tarball.
Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000915/829a43c7/attachment.bin
