[GRASS5] Digging for license problems
David D Gray ddgray at armadce.demon.co.uk
Wed Sep 13 10:36:04 EDT 2000
Bernhard Reiter wrote:
> David,
> On Fri, Sep 08, 2000 at 10:47:29PM +0000, David D Gray wrote:
> [ Numerical Recipe Stuff in GRASS ]
> > It's also largely the same set of basic math routines
> > implemented in gsl (just a little more complete at present - but not so
> > well designed as gsl). Anyway in this case it's just a matrix inversion
> > and multiplication problem. If that's OK with the author, they should be
> > easy to replace. I will look into that if I can track down the authors.
> I think that you can start replacing the code anyway.
> And I would be grateful if you did.
> There is not much what the author of the grass command
> can do about it anyway.
>         Bernhard
> Professional Service around Free Software                (intevation.net)
> The FreeGIS Project                                         (freegis.org)
> Association for a Free Informational Infrastructure            (ffii.org)
>    Part 1.2Type: application/pgp-signature
I will replace the linear algebra routines some time over the next few
days.
David
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
