[GRASS5] Digging for license problems
Bernhard Reiter bernhard at intevation.de
Tue Sep 12 12:54:31 EDT 2000
David,
On Fri, Sep 08, 2000 at 10:47:29PM +0000, David D Gray wrote:
[ Numerical Recipe Stuff in GRASS ]
> It's also largely the same set of basic math routines
> implemented in gsl (just a little more complete at present - but not so
> well designed as gsl). Anyway in this case it's just a matrix inversion
> and multiplication problem. If that's OK with the author, they should be
> easy to replace. I will look into that if I can track down the authors.
I think that you can start replacing the code anyway.
And I would be grateful if you did.
There is not much what the author of the grass command
can do about it anyway.
	Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project				            (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000912/0f6c9ab3/attachment.bin
