[GRASS5] r.null bug or gis library bug?
grass at geni.knu.ac.kr
Thu Sep 7 16:18:58 EDT 2000
hi all,
r.null has bug:
r.mapcalc "tmp=2.0"
r.null map=tmp setnull=2.0
Floating exception error occurred.
1. Size of f_range file changes to zero while running r.null.
2. G_number_of_cats() called on line 316 in src/raster/r.null/null.c
3. G_read_range() called on line 395 in src/libes/gis/cats.c
4. G_read_fp_range() called on line 209 in src/libes/gis/range.c
5. returns 2 on line 156 in src/libes/gis/range.c
because f_range size is 0.
6. G_get_fp_range_min_max() set drange->min, drange->max to NULL
as drange->first_time == 1
7. Now, trying to assign double NULL value(means NaN) to integer var.
==> BUG
does anyone have idea?
Regards,
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
