[GRASS5] New dig 5.0 format with categories and z-coordinate
Markus Neteler
neteler at geog.uni-hannover.de
Thu Sep 7 13:55:26 EDT 2000
On Thu, Sep 07, 2000 at 03:25:20PM +0200, Radim Blazek wrote:
> Proposal for new dig 5.0 format with categories and z-coordinate.
Dear Radim and David,
many thanks for the long awaited proposal! I am shure that an
updated vector format would increase the acceptance of GRASS.
If you allow, a question concerning the Z-coordinate support:
Do you think of tilted vectors (maybe 2.5D vectors) or even
of full 3D vectors to construct geometric volumes like houses
or whatever? The latter would require a format which allows to
stack vectors and have vertical vectors etc.
Please don't feel bothered of my question, I just want to
understand your proposal.
Yours
Markus
> General:
> Each element may have none, 1 or more categories (cats).
> More cats are distinguished by category numbers (cat_num).
> Only one cat with cat_num=1 will be used at this stage
> and multi-category support on modules level will be added in
> future.
> Z-coordinate will be optional and both 2d and 3d files may
> be written.
> Implementation steps:
> 1. Define new dig format:
> like 4.x but in:
> - head : Add type field for 2d/3d
> - body : - between element type and number of coordinates is inserted:
> - number of categories 0-255 (1 byte)
> - category number(s) 1-65535 (n_cats * 2 bytes)
> - category(s) 1-4294967295 (n_cats * 4 bytes)
> - for 3d files z coordinate is written in the same style as x,y
> 2. Define new structures and write functions:
> #define CENTROID 0x08
> #define FILE_CENTROID 3
> typedef unsigned char VCNCATS;
> typedef unsigned short VCCATNUM;
> typedef unsigned int VCCAT;
> struct line_cats {
> VCNCATS n_cats; /* number of vector categories on one element */
> int alloc_cats; /* size of allocated space */
> VCCATNUM *cat_num; /* pointer to field of category numbers */
> VCCAT *cat; /* pointer to field of categories */
> struct line_pnts {
> double *x;
> double *y;
> double *z; /* null for 2d */
> int n_points;
> int alloc_points;
> struct line_cats *Vect__new_cats_struct (void);
> int Vect_append_cat ( struct line_cats *, VCCATNUM, VCCAT);
> int Vect_read_next_cats_line ( struct Map_info *, struct line_cats *,struct line_pnts *);
> long Vect_write_cats_line ( struct Map_info *, int type, struct line_cats *, struct ine_pnts );
> ( for backward compatibility this function duplicates cats to dig_att file
> so that old modules can work with new dig files )
> Vect_read_next_line( ) - rewrite to read both 4.x and 5.0 2d/3d
> and of course all functions called by these and some others.
> 3. Rewrite v.build to support both dig 4.0 and 5.0.
> Write v.dig module for conversion from built dig_plus to dig5.0.
> 4. Request for testing on other platforms. Result of v.dig and v.support
> should be the same as original dig_plus and all modules should work
> with dig in 5.0 correctly.
> 5. Rewrite all modules which read from dig_plus (level2) or from
> other sources (v.in.*) to new dig format.
> 6. Rewrite remaining modules which read from dig file. Here is the problem
> because if module writes dig5.0, it must also read in dig5.0 format and
> so imput file must be converted by v.support and v.dig first.
> David D Gray, Radim Blazek
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
