[GRASS5] r.topmodel timezone problem
Justin Hickey jhickey at hpcc.nectec.or.th
Thu Sep 7 05:09:20 EDT 2000
Dear Huidae Cho and others
I'm trying to compile grass on our SGI machines and I have found that
the code in src/raster/r.topmodel/file_io.c access a time zone variable
in the tm struct inside /usr/include/time.h. Both SGI and Cygwin do not
have that variable in their tm struct. Since it is better to solve a
problem directly instead of using preprocessor #ifdef's could the time
zone value be replaced with the POSIX tzname (also in time.h)? Or since
the time zone is only used as output, can it be removed completely? How
important is it to your program Huidae?
Just some suggestions.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
