[GRASS5] NVIZ-RST-licence
Bernhard Reiter
bernhard at intevation.de
Wed Sep 6 10:34:35 EDT 2000
Dear Helena,
thanks for resolving the issue so fast.
I will make the changes in the CVS version tomorrow.
On Mon, Sep 04, 2000 at 05:45:00PM -0500, Helena Mitasova - staff wrote:
> You may not have noticed but s.surf.rst had the same
> statement as NVIZ regarding its commercial use.
> I asked Bernhard to change this statement
> so that it complies with GPL and GRASS5.
> As a related issue, I would like to ask that if you want to
> change s.surf.rst and replace it in GRASS please
> create a version with a new name (e.g. s.surf.rst1).
> We did the same when we switched from s.surf.tps to
> s.surf.rst and kept the old program
> in GRASS untill s.surf.rst was thoroughly tested by several years
> of use. The code is pretty complicated and introduced
> bugs may distort the results only for special cases
> and can be very hard to find and fix.
As you know CVS preserves all prior versions.
We should keep a copy of the old and tested code in the distribution.
Regards,
Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000906/6914e522/attachment.bin
