[GRASS5] Driver Update
Glynn Clements
glynn.clements at virgin.net
Mon Apr 30 14:44:34 EDT 2001
Justin Hickey wrote:
> > The fact that Do_work(1) gets called a second time suggests that all
> > of the data has been sent. Or, at least, the driver isn't blocking
> > trying to send it. I've commited an update to
> > src/display/devices/lib/command.c which checks the return value from
> > the write() call, in case that's failing for some reason.
> Are you sure you committed the change? I updated the file and CVS
> reported it as an M update which means the differences are from my local
> file. So I looked through the file but did not see any changes for the
> write() command. Just curious.
No; it appears that I didn't.
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
