[GRASS5] Driver Update
Glynn Clements glynn.clements at virgin.net
Sat Apr 28 16:40:07 EDT 2001
Markus Neteler wrote:
> > > I have tested some modules:
> > > > d.display
> > >  -> not o.k., needs the R_stabilize()
> > Any specific cases? d.display is quite a large program, which is why I
> > didn't try to fix it there and then.
> Sure, sorry. I loaded a raster map, it was only displayed when "wiping" the
> monitor with another window. If you start it and load a raster map, it won't
> appear.
Odd; I don't get this behaviour. Furthermore, I don't see how it could
occur.
d.display repeatedly opens and closes the driver, doing very little in
between. R_close_driver() calls R_stabilize(), so all output should be
flushed whenever the driver is closed.
Running "fgrep R_ *.c" shows that, in all but three cases, there are
only between one and three statements between R_open_driver() and
R_close_driver(). The exceptions are the code to draw raster maps in
zoom.c and show_cell.c, and the setup code in setup.c (which, if it
weren't for the nine calls to Dnew() to create the frames, would only
have three statements).
The code for displaying a raster map (in show_cell.c; the code in
zoom.c is very similar) is:
	if (R_open_driver() != 0)
		G_fatal_error ("No graphics device selected");
/* Draw cell map */
	G_get_window(&wind) ;
	G_set_window(&wind) ;
	Dchoose(MAP.name) ;
	Derase("black") ;
	fprintf (stdout,"\n\n  Displaying map %s from mapset %s\n", mapname, mapset);
	Dcell(mapname, mapset, 0) ;
/* Draw tiny map */
	G_get_default_window(&wind) ;
	Dchoose(REF.name) ;
	R_close_driver();
I don't see how this can produce the behaviour which you describe,
unless d.display terminates suddenly (you don't report this as
happening; was d.display still running?).
However, premature termination does appear to be a real possibility;
when I tried testing it, attempting to draw elevation.dem (from
spearfish) twice in succession caused d.display to segfault on the
second attempt. The segfault was in realloc(), which suggests heap
corruption.
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
