[GRASS5] Re: [GRASSLIST:1775] r.in.bin
Glynn Clements glynn.clements at virgin.net
Fri Apr 27 15:53:15 EDT 2001
Glynn Clements wrote:
> > I am not sure I know what the bug is that is being described above. It
> > sounds like there might be a problem with how the signed integers are
> > converted. This was a routine that I took from the original r.in.bin and
> > never really tested too much.
> > However, if it works with one projection and not another (XY & Lat Lon),
> > then there is probably something else wrong.
> > Have you applied your fix to the CVS yet Glynn? If not you could email
> > it to me and I will take a look to see if something jogs my memory.
> My fix doesn't fix Jan-Oliver's problem (negative altitudes in an x-y
> location).
Sorry, it doesn't fix Yan Fitterer's problem; it probably does fix
Jan-Oliver's problem.
It has now been comitted to CVS.
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
