[GRASS5] Driver Update
Glynn Clements
glynn.clements at virgin.net
Fri Apr 27 14:11:24 EDT 2001
Markus Neteler wrote:
> > > So we have to watch out now for any module with backing store problems
> > > (when using the latest Xdriver version). It can be simply fixed like
> > > d.rast.edit. Another candidate is v.digit, there may be more modules
> > > needing the R_stabilize() function.
> > I've done a quick scan of anything that might need changes (i.e. by
> > looking for libraster.a in the build output).
> > The following are the ones which couldn't be quickly confirmed to be
> > OK or fixed.
> I have tested some modules:
> > d.display
> -> not o.k., needs the R_stabilize()
Any specific cases? d.display is quite a large program, which is why I
didn't try to fix it there and then.
> > i.class
> -> raster is o.k., but the vector lines are not drawn unless you
> accept them.
> Test usage: use i.group to generate a group and a subgroup of at least
> two raster images (could be anything for this). Then start i.class,
> enter some file names as queried, then "define region"/"draw region" to
> draw vector lines as sample areas. Then drawing, the lines *should*
> be seen (the aren't unless you hit the right mouse button to complete).
OK; this seems to be confined to draw_region().
> > i.points3
> -> o.k. for display
> Bug: If setting target reference point, nothing happens (not displayed,
> not accpeted). Note: i.points3 is *much* more convenient than
> i.points and it merges i.points and i.vpoints. We should get this
> working.
So this bug isn't related to R_stabilize()?
> > i.vpoints
> -> raster o.k., vector maps not displayed at all (bug)
> bug: full screen not restored (frames not removed). Anyway, i.points3
> is my recommendation.
So it doesn't need fixing?
> > d.fix.ortho (src.contrib/SCS)
> -> the digitizing line is not shown yet (needs fix)
get_shift() has the drawing code commented out. Should this be
re-enabled?
> A related problem I found:
> If you break a displaying module with CTRL-C, the monitor is blocked:
> GRASS:~ > d.display
> # displaying something, then CTRL-C to kill due to above problems
> GRASS:~ > Monitor <x0>: Premature EOF
> GRASS:~ > d.erase
> Same story with d.rast: if you CTRL-C it, the monitor is blocked.
> In past this treatment was accepted and the monitor didn't die.
> Closing is (of course) still possible. Could you change the treatment of
> "Premature EOF" in the monitor to keep the monitor working?
This implies that some state is being retained between connections.
This shouldn't happen, and I can't immediately see how it is
happening. I'll look into it.
> If the user forgets to enter the right mouse button (to leave d.zoom or
> another interactive display tool), the monitor is of course blocked as it
> waits for the right mouse button. If you already start the next display
> command like d.rast, nothing happens (as expected). If you *then* click
> right mouse button, the monitor get's back to function and the message
> occurs:
> Monitor <x0>: Caught SIGPIPE
> Then everything is o.k. What I want to say: Could you change the driver to
> react in case of "Premature EOF" as when "Caught SIGPIPE" occurs?
It does; both cases "break" from the inner loop (get_command,
process_command), close the connection and wait for the next
connection.
Of course, this doesn't necessarily translate into the desired
behaviour; I'll certainly look into improving the robustness driver is
as robust as possible.
NB: The case where the client quits while waiting for a mouse click
shouldn't have changed at all; the Get_location_with_* functions all
have their own event loop, which doesn't return until a button is
pressed. This isn't straightforward to change (it can be done, but
it's potentially de-stabilising).
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
