[GRASS5] 5.0.0pre1 on mac osx
andy agena
andya at inebraska.com
Wed Apr 25 12:59:14 EDT 2001
Hi Malcom:
i got a late start today, sorry for the delay in replying. i really
appreciate the time you're taking to help me out.
>> /usr/bin/ld: Undefined symbols:
>> __XErrorFunction
>> __XIOErrorFunction
>> __Xdebug
> These should be in libX11.a. (I'm assuming static libraries here.)
> Check for
> them elsewhere, in /usr/X11R6/lib do a 'grep XErrorFunction *.a'. It
> should
> report some file matches, if these are defined. If so, do a strings on
> the file
> that is reported and pipe to 'grep ErrorFunction' ( strings foo.a | grep
> ErrorFunction). Look for close mismatches. Also, grep for these
> strings in
> /usr/X11R6/include and /usr/X11R6/include/X11 header files. Maybe they
> are
> redefined. If you find libraries that have these check in your gmake5
> output
> file to see if the libraries needed are on the line creating XDRIVER.
> If they
> are redefined in an include file, you may need to add the #include
> statement in
> the source file.
This part doesn't make sense to me; the first grep turns up the three
files using "ErrorFunction", yet strings on these files doesn't show it
(so I tried grep'ing just Error):
[localhost:/usr/x11r6/include] root# grep ErrorFunction *.a
grep: No match.
[localhost:/usr/x11r6/lib] root# grep ErrorFunction *.a
Binary file libFS.a matches
Binary file libX11.a matches
Binary file libXext.a matches
[localhost:/usr/x11r6/lib] root# strings libX11.a | grep ErrorFunction
Error parsing argument "%s" (%s); %s
XProtoError
/usr/X11R6/lib/X11/XErrorDB
ErrorType.ErrorNumber
XError
X Error
ErrorSerial
Error Serial #%d
[localhost:/usr/x11r6/lib] root# strings libFS.a | grep Error
FSProtoError
FSError
FS Error
ErrorSerial
Error Serial #%d
[localhost:/usr/x11r6/lib] root# strings libXext.a | grep Error
XProtoError
XProtoError
XProtoError
XProtoError
XProtoError
XProtoError
> To recompile, you will need the headers. Look for other tcl*.h or
> tk*.h files.
> These can be obtained from various sites, but they should match the
> version of
> the libraries that you have (i.e. 8.0.3, 8.0.5, etc.).
I did a search a google and found a bunch of dead links and
www.opensource.apple.com keeps timing out.
Jeshua: do you mind popping your tcl/tk .h into a tarball and zapping
them to me?
What puzzles me about these *.h files is that I had the grass 5beta11
running before with Jeshua's tcltk tarballs (bin and lib). Perhaps
apple had included them with the public beta, but removed them in the
1.0 release.
> There are small
> differences in some of the versions. Based on where you found the
> libraries,
> look for something in /usr/local/include. If you still can't find
> them, these
> can be provided. Until you get the XDRIVER working, the tcltkgrass
> won't be as
> much fun, so fix this later.
> For the lib files, you don't need these in your path, you need to tell
> gmake5 to
> use them. To do that, look at the file in src/CMD/head/ that matches
> your system
> architecture. For cygwin it looks like
> src/CMD/head/head.i686-pc-cygwin. It
> should match the architecture that you are using, like the bin.** and
> dist.**
> directories that were created by install. The tcl/tk lines should look
> like the
> lines in my head file here:
> #tcl/tk stuff
> TCLINCDIR = -I/usr/local/include
> TKINCDIR = -I/usr/local/include
> TCLTKLIBPATH = -L/usr/local/lib
> TCLTKLIBS = -ltk8.0 -ltcl8.0
the culprits:
PNGLIB = -L/usr/local/lib -L/usr/X11R6/lib -L/usr/lib
#JPEGINCPATH = -I/usr/X11R6/include/ -I/usr/include/gr
-I/usr/local/include -I/usr/include
#JPEGLIBPATH = -L/usr/local/lib -L/usr/X11R6/lib -L/usr/lib
JPEGINCPATH =
JPEGLIBPATH =
JPEGLIB =
TIFFINCPATH =
TIFFLIBPATH = -L/usr/local/lib
#tcl/tk stuff
TCLINCDIR =
TKINCDIR =
TCLTKLIBPATH =
TCLTKLIBS =
my setup:
[localhost:/usr/local/lib] root# ls
.DS_Store libtiff.a libz.a php.ini tk8.0
libpng.a libtk8.0.a mysql tcl8.0 tkConfig.sh
libtcl8.0.a libwrap.a php tclConfig.sh
Should I add "-I/usr/local/lib" for tcltk, png, and tiff (still haven't
tracked down the jpeg file) and 'make' again?
>> my wish8.0 is in /usr/local/bin, which was already in my PATH.
> Create a link to this file. (cd to /usr/local/bin and do 'ln -s
> wish8.0 wish')
creating the link got rid of the tcltk error, now its just:
GRASS 5.0.0pre1 > tcltkgrass &
[1] 486
>>> GL libraries and includes should be under the X11 path, in something
>>> like
>>> /usr/X11R6/lib and /usr/X11R6/include/GL or /usr/X11/lib and
>>> /usr/X11/include/GL. Check one of the Mac OS X sites, to see if
>>> others
>>> have this
>>> available...
>> I have libGL.a and libGLw.a in /usr/X11R6/lib, plus a bunch of GL* in
> Check to see if these were found by configure. Look at the head file
from my head.* file:
#openGL files for NVIZ/r3.showdspf
OPENGLINC = -I/usr/X11R6/include -I/usr/X11r6/include
OPENGLwINC = -I/usr/X11R6/include -I/usr/X11r6/include
OPENGLLIB = -L/usr/lib -L/usr/local/lib -L/usr/X11R6/lib
-L/usr/X11r6/lib -lGL
OPENGLULIB =
LGLWM =
OPENGL32 =
my setup:
[localhost:x11r6/include/gl] root# pwd
[localhost:x11r6/include/gl] root# ls
GLwDrawA.h GLwMDrawA.h gl.h glx.h glxtokens.h
GLwDrawAP.h GLwMDrawAP.h glext.h glxint.h osmesa.h
Should I add "/GL" at the end of the head.* for this one?
Thanks,
Andy
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
