[GRASS5] Driver Update
Justin Hickey jhickey at hpcc.nectec.or.th
Wed Apr 25 02:57:11 EDT 2001
Hi Glynn
Glynn Clements wrote:
> Do you have strace() or similar?
Hmmpf. It figures that strace on SGI is different from Linux. The best I
can do here is provide you with a system call trace, but I don't know if
that will be useful to you. Please let me know if you want it anyway.
> If so, a trace of the XDRIVER
> process would help a lot. If not, could you add some printf()s to
> src/display/devices/lib/main.c and see if that tells us anything.
The following is the output with some fprintf()'s and some comments by
me (preceeded with //)
using default visual which is TrueColor
Visual is read-only or using a private colormap
ncolors: 32768
allocating memory...
About to call prepare_connection_sock
About to call get_connection_sock
Graphics driver [x0] started
About to call Do-work (0)
About to call Do-work (1)
// Slight pause here
Warning - no response from graphics monitor <x0>.
Check to see if the mouse is still active.
ERROR - no response from graphics monitor <x0>.
About to call close(_wfd)
Problem selecting x0. Will try once more
// Again the pause
// d.mon ends
// These 2 lines are continually printed until I close the monitor
// window
I don't know if this is helpful to you or not. Please let me know if you
want me to place print statements in other places in the code.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
