[GRASS5] Re: [Fwd: ArcInfo ungenerate]
Michel Wurtz
mw at teledetection.fr
Tue Apr 24 08:44:41 EDT 2001
Malcolm Blue wrote:
> Markus,
> I think that GENERATE format can include commas. The following quote is from a
> response on the ESRI knowledge base describing how to create a GENERATE file from
> INFO:
> 'The output file created will be used with the GENERATE
> command, which will read commas as field delimiters. '
> It appears either space or comma can be used.
Well... I spent a little time on v.in.arc : the problem is in
process_inp.c, which looks :
int process_inp (char *inp)
G_remove_commas(inp);
while(*inp)
if((*inp=='D')||(*inp=='d')) *inp='e';
inp++;
return 0;
G_remove_commas() appears only in v.in.arc and v.in.arc.pg (which is
based on v.in.arc). the function is define in libes/gis/commas.c,
and the comment you found before the function is :
/* removes commas from strings representing a number
1,234,567 becomes 1234567
1,234,567.89 becomes 1234567.89
12,345 becomes 12345
1234 stays 1234
There is also a G_insert_commas() function for the opposite, that is a
little more used. Here is the command i used from the grass/src dir :
bash-2.03$ find . -name '*.c' -exec grep G_insert_commas {} /dev/null \;
./src/libes/gis/commas.c:int G_insert_commas(
./src/libes/gis/edit_cellhd.c: G_insert_commas(buf);
./src/raster/r.report/cmd/format.c: G_insert_commas (temp);
./src.contrib/SCS/vector/v.report/cmd/format.c: G_insert_commas (buf);
so it appears that
1- G_remove_commas() in never used except where it causes trouble
2- G_insert_commas() seems only used to put commas on rare occasions
Should we keep them in the future release, or modify
src/libes/gis/edit_cellhd.c, src/raster/r.report/cmd/format.c and
src.contrib/SCS/vector/v.report/cmd/format.c (which seems a duplicate
from the former)
In the meantime, I have modified src/mapdev/v.in.arc/process_inp.c
and src.garden/grass.postgresql/v.in.arc.pg/process_inp.c to
replace commas by spaces. This should correct the problem.
Michel WURTZ - DIG - Maison de la télédétection
500, rue J.F. Breton
34093 MONTPELLIER Cedex 5
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
