[GRASS5] Again Solaris/tar/Makefile problem
Federico Ponchio ponchio at mail.dm.unipi.it
Mon Apr 23 08:05:39 EDT 2001
	i finally got the Makefile (i have not easy access to the solaris
machine, sorry for being late).
This is the line working for me:
${SHEL} -c "cd ${GISBASE} ; tar cBf - bin | (cd ${INST_DIR} ; tar xBf - )
; true"
Notice the missing slash after bin. That was the problem. How silly.
Federico.
On Mon, 23 Apr 2001, Markus Neteler wrote:
> Hi Federico
> (cc grass5)
> On Mon, Apr 23, 2001 at 07:55:29AM +0100, Glynn Clements wrote:
> > Justin Hickey wrote:
> > > > >       one of the problems on Solaris tar is that options MUST go
> > > > > first (and i think it depends on getopt in the libraries which
> > > > > behaves strangely). I installed Grass on a solaris, and solved the
> > > > > tar problem that way (just moved options at the beginning).
> > > > Huh? The options are at the beginning:
> > > >         ${SHELL} -c "cd ${GISBASE} ; tar cBf - bin/ | (cd ${INST_DIR}  ; tar xBf - ) 2>/dev/null ; true"
> is this order of tar parameters working for you? Just to confirm!
> > > > We're not using the newer "dash" form (switches preceded with dashes,
> > > > with arguments immediately following the corresponding switch).
> > > Has this been solved yet? I just don't want this to be ignored again.
> > Nothing has changed yet. I think that the relevant issue is a few
> > messages back:
> > > Is it not safe to simply omit the trailing slash?
> > Unless someone actually says "no, FooOS complains if you omit the
> > trailing slash", I suggest that we remove it.
> Usually we find out quickly if we change the cvs (brute force method).
> O.k., not very elegant, but we need to find out now.
> Regards
>  Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
