[GRASS5] Volunteer wanted for CELL driver color problem
Markus Neteler neteler at geog.uni-hannover.de
Wed Apr 18 10:46:13 EDT 2001
On Wed, Apr 18, 2001 at 10:42:38AM -0300, Bob Covill wrote:
> Markus Neteler wrote:
> > Bob, Eric,
> > On Wed, Apr 18, 2001 at 10:23:18AM -0300, Bob Covill wrote:
> > > Markus,
> > > It has been a long time since I have used the CELL driver, but I decided
> > > to take a look at it for investigating the color problem.
> > > Unfortunately I got off to a bad start. When I execute d.mon start=CELL
> > > I get the following error maessage:
> > > Usage:  CELL [-] "input_fifo output_fifo"
> > > No socket to connect to for monitor <CELL>.
> > > Problem selecting CELL. Will try once more
> > > The CELL driver has been built and installed.
> > > Any idea why it will not start, socket / fifo problem ??
> > This is strange:
> > GRASS:~ > d.mon CELL
> > Graphics driver [CELL] started
> > Wait for 'READY'
> > READY
> > GRASS:~ > d.mon stop=CELL
> > Monitor 'CELL' terminated
> > GRASS:~ > d.mon start=CELL
> > Can't bind to socket for monitor <CELL>. Already in use?
> > Socket is already in use or not accepting connections.
> > Use d.mon to select a monitor
> > Obviously the start= parameter confuses d.mon. Without it works.
> > Maybe again the timing story?
> >  Markus
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
> Markus,
> I tried ...
> d.mon CELL
> and got the same error message.
Well, trying this a second time it fails again.
> The error you reported above does sound like the timing issue. Try ...
> d.mon -s start=CELL
> followed by ...
> d.mon select=CELL
> to see if that helps.
d.mon -s start=CELL
GRASS:~ > d.mon select=CELL
Nope.
> The error that I am getting is on my Solaris machine. I try my Linux
> machine a little later and see if the same problem exists there, trying
> to start the CELL driver.
Bob, did you try the code piece from Eric recently posted on this channel?
I'll try that if it helps here.
Markus
