[GRASSLIST:1733] [GRASS5] solution for vt100 problem on Mac OS X
Justin Hickey
jhickey at hpcc.nectec.or.th
Wed Apr 18 07:13:58 EDT 2001
Hi Andy
andy agena wrote:
> Hi list:
> [this is my third attempt to post this solution to the GRASSLIST, as
> there's something wrong with @baylor.edu--if someone on GRASS5 could
> forward this to the GRASSLIST, I'd appreciate it. I wrote to Art and
> George directly with the solution]
> If a Mac OS X (pb and 1.0) user tries to fire up GRASS, the following
> error occurs:
> Error opening terminal: vt100
> The solution (kudos to strobe) is to cd to the directory where your
> spearfish directory is (i.e. if its found in /opt/spearfish, cd /opt)
> and enter the following:
> grass5 spearfish/PERMANENT
> Voila!
Although this is a workaround, it does not actually solve the problem.
Is there anyone with insight as to what is causing the problem? It would
be nice to solve this problem if it is a Grass problem.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
