[GRASS5] v.in.arc: import files
Rich Shepard
rshepard at appl-ecosys.com
Tue Apr 17 12:27:49 EDT 2001
On Tue, 17 Apr 2001, Markus Neteler wrote:
> the v.in.arc is the exception from above rule: It does *not* read from
> the current working directory but only from $LOCATION/arc/ (like the
> v.in.dxf, too). All other import modules read from current working
> directory. Therefore I propose a change in v.in.arc/v.out.arc |
> v.in.dxf/v.out.dxf to reach the wanted consistency.
Markus,
Well-l-l, ... m.in.e00, v.in.mif, and v.in.shape all require the
fully-qualified path name to work. Just the current directory won't do.
That's why I thought the issue was more general.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
