[GRASS5] Re: Current GDAL problem
mberglund matt at rcinfo.net
Tue Apr 17 10:11:40 EDT 2001
Other pertinent information that I should have included in the previous
post is:
I have tried the binary package of GDAL with the my grass compile: failure
I have tried the variations on the compilation of GDAL: failure
Is python _required_ for the gdal bridge to work. If so, that could be the
reason. I do not have all the headers required for a compile of GDAL with
python.
Grass and tcltkgrass seem to work just dandily.
NVIZ still fails with:
The papers are available at
http://www2.gis.uiuc.edu:2280/modviz/
Unable to load map
Unable to load map
Loading Data
child killed: segmentation violation
    while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script elevation=4117ne1.1
-name NVIZ >&@stdout"
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $CMD -name NVIZ >&@stdout
    (file "/usr/local/grass5/bin/nviz2.2" line 92)
Finished
But it should be noted that there is no elevation data for 4117ne1.1, so
why is it looking for some?
In any event, this is what I have found, if it is usefull, please let me
know. If not, please don't throw tomatoes!
Later,
Matt
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
