[GRASS5] java jni bridge for grass
David Lozano Argel
sldla996 at udea.edu.co
Mon Apr 16 23:31:15 EDT 2001
We are working in a project already, It consist in make a bridge between
GRASS and Internet (JAVA or another). If you want colaborate, we will
gracefull.
Sorry my english.
On Tue, 17 Apr 2001, Andreas Lange wrote:
> John,
> as far as i remember the grass.java libraries are currently _not_
> adopted to the grass5 floating point libraries, so they are essentially
> useless in the current form.
> This is IMHO the reason that they are not installed.
> But if someone wants to work on the floating point/grass5 interface it
> would be great to know how you built them.
> cu,
> Andreas
> John Huddleston wrote:
> > Grass5 list,
> > I built the src.garden/grass.java jni system for Cygwin. There
> > was no install target in the gnumakefile. I have the jar
> > file, docs, and the DLLs.
> > Where should they be installed? Anyone interested?
> > John Huddleston, P.E.
> > USDA Computer Engineer
> > (970) 490-8352 (Gpsr)
> > huddleston at gpsr.colostate.edu
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
> Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
xxxxx
xx xxx
xx xx x xxxxx
xxxxx xx x xx xxxxxx
xxx xxx xx
xx xx
xx
sldla996 at bochica.udea.edu.co
zoftwar at yahoo.com
david at lozano.as
dlozano at dada.udea.edu.co
lenin at cigoto.8k.com
zoftwar at latinmail.com
