[GRASS5] how to install software grass into the linux platform...?
Robert Lagacé
lagace at echo.grr.ulaval.ca
Tue Apr 17 10:00:48 EDT 2001
ja id wrote:
> hi!
> I want to develop one project that related to this software grass..but i had
> a problem to solved in by myself..i want to know how can i run this
> software grass into linux platform....and then to the server sun solaris
> sparc... ?
GRASS is already compiled for Linux and Solaris. So you are OK.
Download the binaries.
> >From: Robert Lagacé <lagace at grr.ulaval.ca>
> >Reply-To: grass5 at geog.uni-hannover.de
> >Subject: [GRASS5] Compilation on HP-UX
> >Date: Mon, 16 Apr 2001 18:08:52 -0400
> >Finally I found time to try compile GRASS on HP-UX.
> >I download the last snapshut of GRASS and proceeded
> >to compile it. So, I run ./configure and got somme
> >checking with negative results. I want to know if they
> >may cause problems.
> >checking for flex... lex
> >??? the REQUIREMENT files say flex no lex is suported.
> >??? flex is available for HP-UX
> >Are they any problems with thoses ?
> >checking for bison... no
> >checking for byacc... no
> >checking for dnet_ntoa in -ldnet... no
> >checking for dnet_ntoa in -ldnet_stub... no
> >checking for seteuid... no
> >checking for initscr in -lncurses... no
> >checking for initscr in -lcurses... yes
> >checking for xdrmem_create in -lsun... no
> >checking for xdrmem_create in -lnsl... no
> >checking for xdrmem_create in -lrpclib... no
> >checking for atan in -lc... no
> >checking for atan in -lm... yes
> >checking for dlsym in -ldl... no
> >I have some missing libraries that are easy to correct.
> >Thanks.
> >Robert Lagacé, professeur
> >Pavillon Comtois
> >Université Laval
> >Ste-Foy, Québec, G1K 7P4
> >tel : (418)-656-2131#2276
> >Fax : (418)-656-3723
> >E-mail : lagace at grr.ulaval.ca
> >If you want to unsubscribe from GRASS Development Team mailing list write
> >to:
> >minordomo at geog.uni-hannover.de with
> >subject 'unsubscribe grass5'
> _________________________________________________________________________
> Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
> If you want to unsubscribe from GRASS Development Team mailing list write to:
Pavillon Comtois
Université Laval
