[GRASS5] Cygwin build for 110401
Markus Neteler neteler at geog.uni-hannover.de
Mon Apr 16 16:23:06 EDT 2001
John,
(hi all)
On Mon, Apr 16, 2001 at 12:55:49PM -0600, John Huddleston wrote:
> Yes, of course, but I did not want to break the Linux build.
> Add $(OPENGL32) in the last line of the Gmakefile.in after
> the -ltiff in the src.contrib/GMSL/NVIZ2.2/src directory
I have modified:
src.contrib/GMSL/NVIZ2.2/src/Gmakefile.in
and changed hard-coded libs to src/CMD/head equivalent variable names.
This should do on every platform. Please let me know if it helps
(along with the updated src/CMD/head.in)
Cheers
 Markus
> ----- Original Message -----
> From: "Markus Neteler" <neteler at geog.uni-hannover.de>
> To: <grass5 at geog.uni-hannover.de>
> Sent: Monday, April 16, 2001 7:39 AM
> Subject: Re: [GRASS5] Cygwin build for 110401
> > John,
> > (Grass5 list)
> > On Sun, Apr 15, 2001 at 08:52:21AM -0600, John Huddleston wrote:
> > > Andreas, (Grass5 list)
> > > I agree let's test it first.
> > > Also, I followed Byars link (see below) Friday and see that the tar build
> > > does not include Postgresql.   Postgresql is available in the contrib section
> > > of Cygwin and does get installed.   It is included in the zip binaries.
> > > Regarding the nviz, I modified the Gmakefile.in to include the words
> > > -lopengl32 -lglu32 -lX11
> > > Then the system uses the Gmakefile.in to create the Gmakefile and it
> > > builds. These come from the Cygwin latest/w32api section.
> > Do you have a general solution for src.contrib/GMSL/NVIZ2.2/src/Gmakefile.in
> > using the OPENGL32 from head file recently included?
> > It would be nice to have it included automagically on every platform.
> > Markus
> > > From: "Andreas Lange" <Andreas.Lange at Rhein-Main.de>
> > > Sent: Friday, April 13, 2001 4:31 AM
> > > > Hi Markus, John, Malcolm,
> > > > i think that we should go first with the installable tar.gz tarball that
> > > > Malcolm uploaded.
> > > > If we upload an untested zip file without instructions to install we
> > > > will get masses of emails asking for help. I can not provide individual
> > > > installation support.
> > > > If the nviz wish is not installed properly, we should modify the
> > > > makefile.
> > > > I still insist to make the whole procedure as general as possible. I
> > > > believe we should not rely on manual tweaking or on individual
> > > > configurations.
> > > > And i don't like the idea of distributing binary files that can not be
> > > > automatically rebuild.
> > > > John, could you please post what you did to compile nviz2.2? Is this
> > > > going through the X11 libraries or with the Windows GUI library?
> > > > Does the StarNet X Server support OpenGL? I don't think so.
> > > > Building PostgresSQL support seems to need the PostgreSQL source
> > > > package, my compile dies with message "missing postgres.h". The Postgres
> > > > package changed several times the last week. We should wait until this
> > > > settles down and we have the opportunity to test the setup.
> > > > I did much testing yesterday and will prepare a short report. v.digit
> > > > has a very unusual behaviour (you have to press RETURN after each
> > > > message), but seems to work generally.
> > > > cu,
> > > > Andreas
> > > From: "B. Byars" <Bruce_Byars at baylor.edu>
> > > To: <wingrass at geog.uni-hannover.de>
> > > Sent: Thursday, April 12, 2001 7:34 AM
> > > Subject: Re: [GRASSLIST:1732] [winGRASS] New winGrass Binaries Available
> > > > Updated at Baylor.
> > > > Bruce
> > > > Malcolm wrote:
> > > > > The new winGrass binaries are available now on
> > > > > the European site.  These should be available
> > > > > soon on the mirrors (including Baylor).
> > > > > Please note the updated installation
> > > > > instructions available from that same site.  To
> > > > > access this new version go to:
> > > > > http://www.geog.uni-hannover.de/grass/5.0winport.info.html
> > > > > Note, also, that there is now a version of
> > > > > tcl/tk compiled for cygwin/XFree86 available
> > > > > from the download directory that should let you
> > > > > use tcltkgrass.
> > > > > As the graphics driver and the tcl/tk interface
> > > > > are very new, these are considered
> > > > > experimental.  Various other parts of the system
> > > > > have been working longer, but not everything has
> > > > > been widely tested on Cygwin.  Please submit
> > > > > feedback to this list so that we can address
> > > > > problems.  If possible, note whether these
> > > > > problems are unique to winGrass, i.e. if you
> > > > > have GRASS on another platform what is the
> > > > > difference between the winGrass version.  A
> > > > > number of the cygwin platform specific issues
> > > > > are listed in the README.html file in the
> > > > > download directory.
> > > > > Cheers,
> > > > > Malcolm
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
