[GRASS5] Cygwin build for 110401
John Huddleston jhudd at lamar.colostate.edu
Mon Apr 16 14:55:49 EDT 2001
Yes, of course, but I did not want to break the Linux build.
Add $(OPENGL32) in the last line of the Gmakefile.in after
the -ltiff in the src.contrib/GMSL/NVIZ2.2/src directory
John
----- Original Message -----
From: "Markus Neteler" <neteler at geog.uni-hannover.de>
To: <grass5 at geog.uni-hannover.de>
Sent: Monday, April 16, 2001 7:39 AM
Subject: Re: [GRASS5] Cygwin build for 110401
> John,
> (Grass5 list)
> On Sun, Apr 15, 2001 at 08:52:21AM -0600, John Huddleston wrote:
> > Andreas, (Grass5 list)
> > I agree let's test it first.
> > Also, I followed Byars link (see below) Friday and see that the tar build
> > does not include Postgresql.   Postgresql is available in the contrib section
> > of Cygwin and does get installed.   It is included in the zip binaries.
> > Regarding the nviz, I modified the Gmakefile.in to include the words
> > -lopengl32 -lglu32 -lX11
> > Then the system uses the Gmakefile.in to create the Gmakefile and it
> > builds. These come from the Cygwin latest/w32api section.
> Do you have a general solution for src.contrib/GMSL/NVIZ2.2/src/Gmakefile.in
> using the OPENGL32 from head file recently included?
> It would be nice to have it included automagically on every platform.
> Markus
> > From: "Andreas Lange" <Andreas.Lange at Rhein-Main.de>
> > Sent: Friday, April 13, 2001 4:31 AM
> > > Hi Markus, John, Malcolm,
> > > i think that we should go first with the installable tar.gz tarball that
> > > Malcolm uploaded.
> > > If we upload an untested zip file without instructions to install we
> > > will get masses of emails asking for help. I can not provide individual
> > > installation support.
> > > If the nviz wish is not installed properly, we should modify the
> > > makefile.
> > > I still insist to make the whole procedure as general as possible. I
> > > believe we should not rely on manual tweaking or on individual
> > > configurations.
> > > And i don't like the idea of distributing binary files that can not be
> > > automatically rebuild.
> > > John, could you please post what you did to compile nviz2.2? Is this
> > > going through the X11 libraries or with the Windows GUI library?
> > > Does the StarNet X Server support OpenGL? I don't think so.
> > > Building PostgresSQL support seems to need the PostgreSQL source
> > > package, my compile dies with message "missing postgres.h". The Postgres
> > > package changed several times the last week. We should wait until this
> > > settles down and we have the opportunity to test the setup.
> > > I did much testing yesterday and will prepare a short report. v.digit
> > > has a very unusual behaviour (you have to press RETURN after each
> > > message), but seems to work generally.
> > > cu,
> > > Andreas
> > From: "B. Byars" <Bruce_Byars at baylor.edu>
> > To: <wingrass at geog.uni-hannover.de>
> > Sent: Thursday, April 12, 2001 7:34 AM
> > Subject: Re: [GRASSLIST:1732] [winGRASS] New winGrass Binaries Available
> > > Updated at Baylor.
> > > Bruce
> > > Malcolm wrote:
> > > > The new winGrass binaries are available now on
> > > > the European site.  These should be available
> > > > soon on the mirrors (including Baylor).
> > > > Please note the updated installation
> > > > instructions available from that same site.  To
> > > > access this new version go to:
> > > > http://www.geog.uni-hannover.de/grass/5.0winport.info.html
> > > > Note, also, that there is now a version of
> > > > tcl/tk compiled for cygwin/XFree86 available
> > > > from the download directory that should let you
> > > > use tcltkgrass.
> > > > As the graphics driver and the tcl/tk interface
> > > > are very new, these are considered
> > > > experimental.  Various other parts of the system
> > > > have been working longer, but not everything has
> > > > been widely tested on Cygwin.  Please submit
> > > > feedback to this list so that we can address
> > > > problems.  If possible, note whether these
> > > > problems are unique to winGrass, i.e. if you
> > > > have GRASS on another platform what is the
> > > > difference between the winGrass version.  A
> > > > number of the cygwin platform specific issues
> > > > are listed in the README.html file in the
> > > > download directory.
> > > > Cheers,
> > > > Malcolm
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
