[GRASS5] Cygwin build for 110401
John Huddleston
jhudd at lamar.colostate.edu
Sun Apr 15 10:52:21 EDT 2001
Andreas, (Grass5 list)
I agree let's test it first.
Also, I followed Byars link (see below) Friday and see that the tar build
does not include Postgresql. Postgresql is available in the contrib section
of Cygwin and does get installed. It is included in the zip binaries.
Regarding the nviz, I modified the Gmakefile.in to include the words
-lopengl32 -lglu32 -lX11
Then the system uses the Gmakefile.in to create the Gmakefile and it
builds. These come from the Cygwin latest/w32api section.
John
----- Original Message -----
From: "Andreas Lange" <Andreas.Lange at Rhein-Main.de>
To: <grass5 at geog.uni-hannover.de>
Sent: Friday, April 13, 2001 4:31 AM
Subject: Re: [GRASS5] Cygwin build for 110401
> Hi Markus, John, Malcolm,
> i think that we should go first with the installable tar.gz tarball that
> Malcolm uploaded.
> If we upload an untested zip file without instructions to install we
> will get masses of emails asking for help. I can not provide individual
> installation support.
> If the nviz wish is not installed properly, we should modify the
> makefile.
> I still insist to make the whole procedure as general as possible. I
> believe we should not rely on manual tweaking or on individual
> configurations.
> And i don't like the idea of distributing binary files that can not be
> automatically rebuild.
> John, could you please post what you did to compile nviz2.2? Is this
> going through the X11 libraries or with the Windows GUI library?
> Does the StarNet X Server support OpenGL? I don't think so.
> Building PostgresSQL support seems to need the PostgreSQL source
> package, my compile dies with message "missing postgres.h". The Postgres
> package changed several times the last week. We should wait until this
> settles down and we have the opportunity to test the setup.
> I did much testing yesterday and will prepare a short report. v.digit
> has a very unusual behaviour (you have to press RETURN after each
> message), but seems to work generally.
> cu,
> Andreas
To: <wingrass at geog.uni-hannover.de>
Sent: Thursday, April 12, 2001 7:34 AM
Subject: Re: [GRASSLIST:1732] [winGRASS] New winGrass Binaries Available
> Updated at Baylor.
> Bruce
> Malcolm wrote:
> > The new winGrass binaries are available now on
> > the European site. These should be available
> > soon on the mirrors (including Baylor).
> > Please note the updated installation
> > instructions available from that same site. To
> > access this new version go to:
> > http://www.geog.uni-hannover.de/grass/5.0winport.info.html
> > Note, also, that there is now a version of
> > tcl/tk compiled for cygwin/XFree86 available
> > from the download directory that should let you
> > use tcltkgrass.
> > As the graphics driver and the tcl/tk interface
> > are very new, these are considered
> > experimental. Various other parts of the system
> > have been working longer, but not everything has
> > been widely tested on Cygwin. Please submit
> > feedback to this list so that we can address
> > problems. If possible, note whether these
> > problems are unique to winGrass, i.e. if you
> > have GRASS on another platform what is the
> > difference between the winGrass version. A
> > number of the cygwin platform specific issues
> > are listed in the README.html file in the
> > download directory.
> > Cheers,
> > Malcolm
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
